I get no errors at all. Check what i mentioned in the post #8
but I try to disassemble files but it outputs no .dsl files and the 12 error lines are present in the output please help me to fix them
I checked that I downloaded the latest version but it doesn't affect the result
please see errors and give me some help to fix them
why it doesn't output any dsl file there?
What version of iasl compiler are you using? Attach a video to explain the process you're doing.
version output of iasl :
Intel ACPI Component Architecture
ASL+ Optimizing Compiler/Disassembler version 20180427(RM)
Copyright (c) 2000 - 2018 Intel Corporation
link to video :
disassembling dsdt
excuse me sir
did you find any solution for these errors?
link to video :
disassembling dsdt
I checked it. The error is due to MDBG. Common is some Lenovo Laptops.
The maciASL version should be RM-1.31 (252.4). maciASL>About
And the iasl version should be the 6.1.
ok but where can I find that maciasl version? I searched and only its versions from 5.1 to 5.7 are available on github
and also how to fix that MDBG related errors?
That means you did NOT followed the guide. Read here:
Read about "Download the tools for the disassembly" and "Disassembling the ACPI Files".
From the refs.txt, remove "External(MDBG, MethodObj, 1)" line.
thanks
I read all of them but I couldn't find the version that you mentioned (RM-1.31 (252.4))
this is the list of versions but there isn't rm-1.31 between them:
mrdarkd
