Asus UEFI
I have tried formatting it but it hasn't worked, do you know how I can format it
When at Disk Utility, simply select your Drive and click on Erase and erase it with the following parameters.
Macintosh HD
APFS
GUID Partition Map
Macintosh HD
APFS
GUID Partition Map
Do you mean my ssd or HDD, or USB, is this a post install task? Because disk utility is not on windows, what "drive" are you talking about
Have you prepared the USB?
This needs to be done during the installation process. It's a step to erase your drive so that you can install macOS.
Oh, so I do not have to format it in windows, I can format it during the install, and I am in the process of finding the kexts for my install USB.
Yes.
scarlywhite
