ALC 255 - Microphone not getting detected
@EliteMacx86
I've removed Apple ALC and backed up my old Apple HDA.
Copied the Insanely Deepak's Apple HDA for ALC 255 and built the kext cache as well.
Then, under Opencore's config.plist's, removed alcid's boot flag and updated the layout id as '13' under device properties for the audio PCI.
Now, no audio equipment is detected.
@EliteMacx86
Provide your Problem Reporting Files.
Do you mean the opencore's boot sequence debug file?
Okay. I'll look into it.
Hello, I would recommend you simply check the sound card drivers, in case it's possible.
natsukiro
