ALC 255 - Microphone not getting detected
Yes, it's recognized as a headphone.
Okay and i guess no input.
Check with the supported Layout IDs on AppleALC page. Provide the tests report.
Yes, no input except the inbult microphone of the laptop.
@EliteMacx86
These are my findings from all the supported layouts for my laptop's codec (ALC 255):
Layout 3 - Headphone OK, Speakers OK, Internal Mic OK, No External Mic
Layout 13 - Headphone Slightly Distorted, Speakers OK, No Internal Mic, No External Mic
Layout 15 - Headphone Distortion, No Internal Speakers, Internal Mic OK, Line in with nothing detected
Layout 17 - Good Audio output but low volume, Headphone OK, Speakers OK, Internal Mic OK, No External Mic
Layout 18 - No port detection, Speakers OK, Internal Mic OK
Layout 21 - Nothing works
Layout 27 - Better Audio output, Headphone OK, Speakers OK, Input - Line in and Internal Mic detected but both of them do not work.
Layout 28 - Good Audio Output, Headphone OK, Speakers OK, Internal Mic, No External Mic
Layout 30 - Good Audio Output, Headphone OK, Speakers OK, No External Mic, Line In detected but doesn’t work
Layout 31 - Good Audio Output (Low volume on Speakers), Headphone OK, Internal Mic Distortion
Layout 99 - Headphone’s Audio Distortion, Internal Mic Distortion, Speakers OK, No External Mic
Layout 11 - Headphone Distortion, Speakers OK, No Internal Mic (Line in), No External Mic
The external mic doesn't function in any of the above layouts.
Reactions: oldman20
@EliteMacx86
I was kinda expecting this. Remove AppleALC and use InsanelyDeepak ALC255 AppleHDA. Make sure you backup your original AppleHDA first.
Backup? I only have Apple ALC's kext. Not Apple HDA.
Please note that AppleHDA is must. Doesn't matters, if you use AppleALC. AppleALC works in conjunction with AppleHDA. It's stored in S/L/E.
fierofree
