Lenovo ThinkPad T470s
When I enable TB type-C, I get this in the tool bar, It's for powering off USB controller. I'm sure it's something I've done wrong when mapping usb ports. I can hide it by dragging it off while holding win key but it comes back when I reboot. How do I hide it permanently ?
Oh BTW the only way I could get the OC 1.0.6 update to work was to update everything but HFS and Open Runtime the drivers. (not sure what that's about)
Decided to change out the intel WiFi/BT card to a BCM4352 so I can use everything as it was intended. Got WiFi up and running with very little trouble. BT on the other hand not so lucky.
BT does not work?
Got only one issue that I have yet figured out. I have everything but AirDrop working. I can receive and see my other devices but can't send anything. I've read up on every solution (fix) I could find with no luck. Can you please take a min to see what I've missed/overlooked? Running Ventuura
  • Config.plist
    Config.plist
First, when you're using DSDT, then you should drop the OEM tables. Same for the other OEM SSDTs as well.
If your WiFi is natively supported, then remove the device properties for it. What's your WiFi model?
Why are you using AppleALC and AppleALCU together?
Enabling XhciPortLimit defeats the purpose of having USBPorts.kext.
Enabling AppleXcpmForceBoost defeats the purpose of XCPM.
naquaada
