How to Fix TSC on macOS
The TSC (Time Stamp Counter) is responsible for ensuring that your CPU is running at its correct defined speed with the correct cores count. However, on some firmware (mostly HEDT/Server and ASUS Laptops) will not write the TSC to all cores which causes a slowdown and every running process is at extremely slow speed. Due to this, when attempting a clean install, the system may enter the boot loop state. To fix this issue, you have 3 options
| Method | Purpose | Notes |
| CpuTscSync | For Laptops For some HEDT Systems | Automatic Sync. No customization is required. |
| VoodooTSCSync | For HEDT Systems | Automatic Sync. No customization is required. |
| TSCAdjustReset | For Skylake X/W/SP and Cascade Lake X/W/S | Need to define threads Customization is required. |
