- Jun 25, 2025
- ASUS ROG GL753V
- Intel Core i7-7700HQ
- NVIDIA GeForce GTX 1050
- 15.x
- OpenCore (Legacy)
Hi everyone,
I’ve been running macOS Sequoia 15.6 on my laptop for about 2 months now, and it’s been working great overall. The only thing I really had to install post-OS setup was HeliPort and the necessary kexts for Wi-Fi, which have been working perfectly.
Yesterday, I decided to finally try getting Bluetooth working. I followed the Bluetooth guide here on the forum, and after some time and effort, I got it up and running — I can pair and use Bluetooth devices just fine.
However, I'm now experiencing a problem:
When the Bluetooth kexts are enabled in my config.plist, my internal audio no longer works.
Interestingly, if I connect a Bluetooth headset, audio works flawlessly through that. But internal speakers are completely dead unless I remove the Bluetooth kexts from the config.
Please let me know:
Thank you all in advance for your help!
Niles
What I’ve Done So Far:
- Running macOS Sequoia 15.6 (Hackintosh)
- Installed Bluetooth kexts based on the guide here
- Bluetooth devices pair and work without issue
- Internal audio only breaks when Bluetooth kexts are active
- Using HeliPort for Wi-Fi (which still works fine)
My Experience Level:
I have a strong background in PC building and configuration, but I’m still pretty new to the Hackintosh/macOS side of things.Request:
I’d like help troubleshooting how to get internal audio working again without disabling Bluetooth.Please let me know:
- What logs, screenshots, or files would be most helpful (e.g., EFI folder, config.plist, IOReg, kextstat, etc.)
- Any ideas on why the audio is being affected
- If there’s a known conflict between certain Bluetooth and audio kexts
Niles
