Intel HD Graphics 630 only 7mb
60hz 1920x1080
Check using a flash if there is a display but without brightness. If not, setup VNC or remote desktop and then boot normally and check if the screen is detected.
The display is just on, or rather the backlight is connected via HDMI to the TV and everything is patched, but the display is black
Inject EDID and then check. Ensure that you have patched the framebuffer properly and have implemented fix for black screen. Also, did you setup VNC?
I don't understand much about hackintosh, but what is VNC and how to make an Inject on EDID and apply a patch to fix the black screen..
Let's make it simple for you. Install any Remote Desktop application and try to connect to this Laptop from any of your system. Then, disable the boot arg and boot it normally. Then, login from your another computer and check whether the display is detected or not. If its detected, then you just need to take care of the black screen. If the display is not detected, you'll have to inject EDID.
That is, do I need Remote Desktop or can I use HDMI too?
If the HDMI port is not tied to the dGPU, you can use HDMI with the monitor.
Look, the display showed up, but the laptop has a black screen with backlight and that's all I need to do?
Similar threads
Roberto Sales
