someone help with this error
i installed python from the official site, im installing high sierra because of the compatibility with g210
You must uninstall that and install it from the Microsoft store.
the cmd just opened a new window and closed at the same time
The recovery image should be downloaded. Check in Recovery directory.
there is nothing, also, i did what you said before, i bought a new graphics card, rx 580 8gb 2048sp
Uninstall old Python. Restart and install the latest Python from Microsoft Store and then use the latest OC recovery script to download the recovery image using the above command. If you still have issues, attach a video to find the issue.
Also, regarding the GPU, its a bad choice cause 2048SP actually requires BIOS modding and does NOT work OOTB.
ploukop
