someone help with this error
winner7k
ASUS PRIME H510M-E
Intel Core i3-10100F
AMD Radeon RX 580 2048SP
15.x
  1. iMac Pro
i cant download the mac recovery, it keeps giving this error, even with the most recent version of opencore
You should use the latest version of OpenCore package to download the Recovery. Also, you must install Python first. Check the guide.
i already have the latest version of python, and i tested both old and latest opencore version
Well, the screenshot attached above says its OpenCore 8.8 which is way old.
yes, but i already tested with the latest version too before posting here
What error do you encounter with the latest version?
the same error, i will attach here the error with the latest version
Sounds good!
Did you install the latest Python from the Microsoft Store?
Also, the correct command should be: macrecovery.py -b Mac-E43C1C25D4880AD6 -m 00000000000000000 -os latest download
Sounds good!
i installed python from the official site, im installing high sierra because of the compatibility with g210
also, there is the error with the latest version of opencore
thadrumr
