someone help me creating a efi using a geforce 210
winner7k
ASUS PRIME H510M-E
Intel Core i3-10100F
AMD Radeon RX 580 2048SP
15.x
  1. iMac Pro
i tried before creating a ryzentosh but i couldnt make it, so i sell my pc and bought other with this specs:
asus prime h510m-e
i3-10100f
16gb 2400mhz
g210
kingston 480gb sata
i have see some people that run big sur on the g210 using 3th gen intel, with legacy video patch, and i wanted help to creating a efi, and if i can run sequoia on it
asus prime h510m-e
i3-10100f
16gb 2400mhz
g210
kingston 480gb sata
Once you're booted off, just use OCLP to patch the system volume and you should be good to go. Also, the other way is to get some low power GPU such as RX460/560 which will work natively on your hardware.
thanks!
AndyB584
