[SOLVED] Need help with installing.
JullianDev
Acer Aspire A514-52 WL Sneezy_WC V1.04
Intel(R) Core(TM) i5-8265U CPU
Intel UHD 620
10.13.x
Hey guys,
I'm new to this kinda stuff and i'm trying to install a "Niresh Catalina.dmg" on my LAPTOP.
Everytime i'm stuck on:
VoodooPS2Mouse: Version 1.9.2 starting on OS X Darwin 18.2
I don't know what to do. So is here anyone who can help me?
Below here I will upload my Laptop SPECS, the bios settings i can see.
Laptop brand: Acer
Model: Aspire A514-52
Motherboard: WL Sneezy_WC V1.04
CPU: Intel(R) Core(TM) i5-8265U CPU
Processor:
Graphics card: Intel UHD Graphics 620 (something with Family?)
RAM: 8GB
BIOS-version/date: Insyde Corp. V1.04, 9-5-2019
SMBIOS-version: 3.0
BIOS-mode: UEFI
I also have 2 hard drives:
  1. 237 GB SSD (original from the laptop)
  2. 465 HB HDD (build it in the laptop)
Some things you probably need to know:
I'm using Windows 10 Education.
  1. I used TransMac to
    1. Format the disk (USB) for mac
    2. Restored with disk image (Niresh Catalina)
  2. I only have acces to a VMware MacOS.
  3. I'm a noob at this.
I want to keep my Windows installation and I want to make it a dual-boot.
Can someone please help me fix this problem?
Hey guys,
Laptop brand: Acer
Processor:
RAM: 8GB
SMBIOS-version: 3.0
BIOS-mode: UEFI
You shouldn't try to install Niresh as it's not upto the mark. Start here:
Your BIOS settings are not upto the mark. Change your BIOS settings to the following.
  • F12 Boot menu to Enabled
  • Disable VTD
  • SATA mode to AHCI
  • Fast Boot to Disabled
  • Secure Boot to Disabled
  • Disable VTD
  • SATA mode to AHCI
Hello,
First, thank you mery much for replying. I will follow the guide you send, and I will put my bios settings to it when I'm trying it again.
Really hope this solves my problem
Hello,
It will.
I'm already stuck on the first step. My terminal says:
sudo /Applications/Install macOS Mojave.app/Contents/Resources/createinstallmedia: command not found.
I'm currently using a VMware with a MacOS Catalina on it..
You should use the Code for Catalina.
Here's the code for Catalina.
sudo /Applications/Install\ macOS\ Catalina.app/Contents/Resources/createinstallmedia --volume /Volumes/USB
Hello,
Thanks for answering. I will try it.
In the guide everytime it's showing "drivers64UEFI" or at the end of the drivers "-64"
It's not showing at me, but I don't think that will be a problem right?
Hi,
I followed the guide and did everything it says, but still no succes. It freezes again. I took a picture when it freezes and uploaded it.
ilikeeatingpeeandpoo
