Wifi/Bt Dongle Buying Advice (Mac Os 15.2)
could you maybe give me some other models that are availible in germany that are tested?
this model has windows drivers that first show up and then never shows up wifi again.
(im refunding) (BCM94360z4)
That's weird. How did you install the drivers and from where?
Only two models that can work well: BCM94352Z and BCM94360NG. You can check on eBay if its not available on Amazon. AliExpress can work too.
from the seller, and after they didnt work from a blogger from china where the chip is popular
What's the device ID?
Can you say me any Intel based WiFi cards all broadcom wont function properly in windows
(for the WiFi section)
Never had any problems with BCM cards in Windows. What problem do you face?
the wifi was just disappearing out of the device manager and windows in general and the device was just not shown but now i bought the intel ax200 and it works perfectly im installing mac os after it again and it will probaly work in mac os sequoia right?
That's weird but as seen on several AMD systems, ACPI patching might be required if the original card is replaced with Broadcom ones. Yes, it works in macOS Sequoia. Limitations apply.
izzykaif
