Wifi/Bt Dongle Buying Advice (Mac Os 15.2)
yeah but it comes in a week or so in the pictures theres 4 antennas
And how do you plan to connect the four antennas?
the 4 antenna clips on the chip
Yes, does your Laptop has four antenna wires to connect on the BCM chip you bought?
no i guess 2 but there are antennas in the package included
How does it matter when your Laptop doesn't have four antennas? This is the reason, you were asked to buy the another module.
there are 4 attenas in the package and i can lay them in the case i guess right?
It doesn't work like that, unfortunately. Just laying down the antenna will not work. In notebooks, the antennas are located on the bezel side mostly and the cable routes from there to the WiFi/BT card.
i know 2 in the monitor and two in the case
this model has windows drivers that first show up and then never shows up wifi again.
(im refunding) (BCM94360z4)
rmayrink
