Wifi/Bt Dongle Buying Advice (Mac Os 15.2)
could you maybe give me some other models that are availible in germany that are tested?
this model has windows drivers that first show up and then never shows up wifi again.
(im refunding) (BCM94360z4)
That's weird. How did you install the drivers and from where?
Only two models that can work well: BCM94352Z and BCM94360NG. You can check on eBay if its not available on Amazon. AliExpress can work too.
from the seller, and after they didnt work from a blogger from china where the chip is popular
What's the device ID?
Write your reply...
newfreedom002
