The firmware reports
Firmware Version: v0 c0
This indicates the firmware is not loading. First, the kext is not in sorted order.
Try under Ventura first. Also, add -btlfxallowanyaddr as boot arg and then check.
What is correct kext order?
Mandatory kexts should load first. Lilu, VSMC, WEG, etc. For WiFi, it should be, AirportBrcmFixup, BrcmFirmwareData.kext, BrcmPatchRAM3.kext, BlueToolFixup.kext
Reordering kexts helped - on Ventura (see attachment). On Sequoia, however - there is PXSX process stalling, and bluetooth section is frozen in system information.
Something might be interfering.
I suppose lack of IOSkywalk and 80211 kexts. I am gonna try adding these and report back
It kinda helped? Its intermittent, one time it works, one time it doesnt. In ventura it works always.
Also Sequoia boots with "You restarted your computer cause of problem".
Managed to fix that by cleaning logs, but bluetooth works only if I boot into ventura and then into sequoia. Guess I will stick to ventura til I get a better wifi card or a real macbook
That's only important for the WiFi, not the BT. The BT should work without those as its on USB bus.
Write your reply...
jpojo
