hi there, is this fix necessary on original hardware? I have a mac pro flashed from 4,1 to 5,1 and upgraded the card to bcm943602cdp + mini pcie adapter for bluetooth 4.2. i get null for the address, despite reinstalling opencore, reapply legacy patches and using an internal usb header hub from mac pro backplane to internal usb 2.0 hub. wifi also works fine. i have already reset nvram 3-5 times as well. any tips? thanks.
OCLP should do it automatically for real Macs. The problem could be something else. Will have to diagnose.
Hi!
I am trying to get fenvi BCM94352Z to work. I managed to get WiFi working by using airportbrcmfixup, but bluetooth doesn't find any devices. I tried running with bluetoolfixup + bcrmpatchram3, no luck there. In addition to that, under USB in system report it says current required is 0. MAC address is getting detect under bluetooth tab there.
Hi!
Can you provide the PR Files?
What macOS version are you using?
The correct combination for BT kexts are:
  • BrcmFirmwareData.kext
  • BrcmPatchRAM3.kext
  • BlueToolFixup.kext
I tried both on Ventura and Sequoia,
I did all three kexts you mentioned. Can you tell me what files I should send?
At bare minimum, EFI+IOReg+System Report+Hackintool PCIe Info
Here are my files. For some reason my bluetooth address became null and version became v0 c0 after reboot and bluetooth toggle does nothing now
Incomplete PR Files. Seems like you forgot to include System Report. You can obtain using About This Mac>System Report>File>Save
kocsik
