Help! Asus ROG GL552VX
geissel
ASUS ROG GL552VX
Intel Core i7-6700HQ
Intel HD Graphics 530 / nvidia 950M
I need your help
I have the following equipment
Main Hardware
  • CPU: Intel Core i7-6700HQ (Skylake)
  • Chipset: Intel HM170 (Sunrise Point)
  • RAM: 16GB DDR4 (Crucial 8GB 2666MHz + Samsung 8GB 2133MHz)
  • Integrated GPU: Intel HD Graphics 530
  • Display: LG Philips LP156WF6-SPB5 (15.6" LCD)
  • Audio: Conexant CX20751/2
Storage
  • SSD: Kingston SM2280S3G2480G (480GB SATA-III)
Connectivity
  • Wi-Fi & Bluetooth: Intel Dual Band Wireless-AC 8260
And I need to install macOS Sequoia
POST DATA, I had to delete the itlwm and Bluetooth kext so the RAR could be uploaded to this forum.
I would be grateful for your attention
I need your help
Main Hardware
Storage
Connectivity
Is there any issue with the installation?
Reactions: geissel
Yes, first I installed Ventura (of course, I had to spoof the graphics for that). Everything was going fine, then I decided to upgrade to Sonoma, but since I had issues, I gave up. Time passed, and I upgraded to Sequoia (I spoofed the SMBIOS).
The update went well, and in this one, I have been trying to enable graphics acceleration, modifying the kext to the point where I got a screen with a prohibition symbol. If you could guide me and help me get back on the right track, I would really appreciate it.
I am attaching the errors I have encountered throughout the modifications, up to the last one, which is marked with the negation symbol.
You will excuse my English since I am using AI to translate. I have also used it as a help to modify some parameters.
Thanks again for your attention.
Although your EFI is not proper, the issue is different. Add -disablegfxfirmware to your boot args. Remove igfxfw=2 and then check.
I also see that you've irrelevant VoodooI2C satellite kexts. Only use what's meant for your hardware.
Reactions: geissel
Hello, I did what you told me in the boot args and also reinstalled the system.
I was editing the graphics settings and managed to get some acceleration, but I’m still missing HEVC.
Do you have any idea how I could fix that and achieve it?
I’m once again grateful for your response.
Attach the EFI to check!
Reactions: geissel
Since the Efi file is large and does not allow more than 20MB, I had to delete the itlwm kext and IntelBluetoothFirmware.kext, but they are complete in the original EFI.
Delete all the device properties except for IGPU (PciRoot(0x0)/Pci(0x2,0x0). Then delete the following keys from it:
AAPL,slot-name
device_type
model
You shouldn't require agdpmod=pikera. Moreover, your BIOS should already support NVMe and you likely don't need to use NvmExpressDxe.efi.
Also, switching to a correct SMBIOS would be preferred. But make the above changes first and then attach the PR files to check.
Reactions: geissel
I had to be absent due to work matters, and now I put into practice what you told me and managed to get acceleration. The issue is that after a few minutes the system freezes on my laptop, and I’m thinking it’s because I signed in to Apple services with my iCloud account.
Here I’m attaching several documents.
Still not as per the guide. Here are a few problems:
- Remove ResetLogoStatus.
- Delete all the device properties except for IGPU (PciRoot(0x0)/Pci(0x2,0x0).
- Why are you using all the I2C satellite kexts? Just I2C+HID should be enough. You can remove the PS2 kexts as well (except for the keyboard).
- When you are using UTBMap to map the USB ports, what's the need to inject UIAC.aml, - when its intended to use with USBInjectAll.kext?
- You were mentioned to remove NvmExpressDxe.efi. Why it has not been removed yet?
What's the SSD model you are using?
Reactions: geissel
kocsik
