Help! Asus ROG GL552VX
geissel
ASUS ROG GL552VX
Intel Core i7-6700HQ
Intel HD Graphics 530 / nvidia 950M
I need your help
I have the following equipment
Main Hardware
  • CPU: Intel Core i7-6700HQ (Skylake)
  • Chipset: Intel HM170 (Sunrise Point)
  • RAM: 16GB DDR4 (Crucial 8GB 2666MHz + Samsung 8GB 2133MHz)
  • Integrated GPU: Intel HD Graphics 530
  • Display: LG Philips LP156WF6-SPB5 (15.6" LCD)
  • Audio: Conexant CX20751/2
Storage
  • SSD: Kingston SM2280S3G2480G (480GB SATA-III)
Connectivity
  • Wi-Fi & Bluetooth: Intel Dual Band Wireless-AC 8260
And I need to install macOS Sequoia
POST DATA, I had to delete the itlwm and Bluetooth kext so the RAR could be uploaded to this forum.
I would be grateful for your attention
I need your help
Main Hardware
Storage
Connectivity
Is there any issue with the installation?
Reactions: geissel
Yes, first I installed Ventura (of course, I had to spoof the graphics for that). Everything was going fine, then I decided to upgrade to Sonoma, but since I had issues, I gave up. Time passed, and I upgraded to Sequoia (I spoofed the SMBIOS).
The update went well, and in this one, I have been trying to enable graphics acceleration, modifying the kext to the point where I got a screen with a prohibition symbol. If you could guide me and help me get back on the right track, I would really appreciate it.
I am attaching the errors I have encountered throughout the modifications, up to the last one, which is marked with the negation symbol.
You will excuse my English since I am using AI to translate. I have also used it as a help to modify some parameters.
Thanks again for your attention.
Although your EFI is not proper, the issue is different. Add -disablegfxfirmware to your boot args. Remove igfxfw=2 and then check.
I also see that you've irrelevant VoodooI2C satellite kexts. Only use what's meant for your hardware.
Reactions: geissel
Hello, I did what you told me in the boot args and also reinstalled the system.
I was editing the graphics settings and managed to get some acceleration, but I’m still missing HEVC.
Do you have any idea how I could fix that and achieve it?
I’m once again grateful for your response.
Attach the EFI to check!
Since the Efi file is large and does not allow more than 20MB, I had to delete the itlwm kext and IntelBluetoothFirmware.kext, but they are complete in the original EFI.
Write your reply...
ambruhidot
