Asus RoG gl552vx Sonoma - Wifi /bluetooth / trackpad/ keys lights
mark_one
asus rog gl552vx
i7-6700hq
GTX970m
15.x
Hello there, as the title says, i got some issues with Intel Wifi card, i tried the tutorial from youtube but no chance. Other than that except bluetooth, trackpad and keyboard lights everything works.
OOC - config.plist
IO80211FamLegacy - 23.0.0
IOSkywalkFam - 23.0.0 as well
nvram - csr-active-config - 03080000
then when i tried to rootpatch i dont have the 1st option either the message that A patch is available.
For keys light, trackpad and bluetooth i would also like to fix them
Thanks guys.
SORRY FOR POSTING INTO DESKTOP THREAD.
OOC - config.plist
Thanks guys.
Seems like you're trying to use Broadcom guide instead of Intel.
@EliteMacx86 ok, i started to apply intel method from your yt video, but i cant add kexts to OOC, any idea?
UPDATE: Now the wifi works, but no bluetooth. Any idea?
also i got that error on OOC.
Kernel-> Add(20)->Bundle Path contains illegal character!
CheckKernel returns 1 error!
Completed validating /Volumes/EFI/EFI/OC/config.plist in 6ms. Found 1 issue requiring attention.
Are not working:
Shut Down function.
Trackpad.
Keyboard backlights.
Bluetooth.
Are not working:
Shut Down function.
Trackpad.
Bluetooth.
No idea without the PR Files.
comsonic
