Need little help in error related to Lilu
👀 I am sorry still this EFI is not AS per the Guide 🥸, I used that tool to Generate EFI , then I made changes as your previous advice and then I kept everything as it is because i am kinda lazy , becuase EFI was\is working without NootedRED graphics accelaration. **Let me hide under the bed**
Not being rude, but if you're lazy and cannot follow the instructions, then best solution is to buy a new Mac. But plugging the cables is also a work and you need to checkout the Mac as well.
This time, I’m fully committed to doing things the right way. I swear I’ll build my EFI from scratch and put in my very best effort to troubleshoot any errors I encounter. If I don't, I’ll respectfully step back from the forum and won’t trouble the community again.
Only just tell me that is NootedRed working with macOS 15.3.1 on similar AMD-based setups, or its just me doing things wrong?
Now macOS and Me , 1 v 1 🥊
Giving up or pursuing is your choice.
That works fine. Recently tested on two Lenovo with 5800H and 7730U
Reactions: AloneWarrior15
✅ SUCCESS !
chun1980
