Need help in Wi-Fi adaptor USB
AloneWarrior15
Victus by HP Laptop 16-e0xxx
AMD Ryzen 5 5600H with Radeon Graphics
RX 5500M(got burned due to short-circuit so currenty not available(disabled))
Realtek Wifi adaptor of my laptop in not compatible with hackintosh, is there any good and cheap wifi adaptor which is easy to use , I bought a Coconut WA04 but it's started working with chris1111 driver and that driver keep giving push button configuration pop on every 20 second and Wi-Fi gets disconnected. 🫥
There are TP-LINK and D-LINK which are known to work without problems if you want to use USB WiFi Adapter.
Which TP-LINK or D-LINK model works with hackintosh and is it plug and play? Can you make a video regarding the USB wifi adapter? Please, It would be very helpful to the community
One of the model is DWA-131 and for TP-LINK, its T2U Plus. You can get a lot more info on Chris's Github.
Alisson de Santana
