GUIDE How to Fix Pink Screen on Intel HD and UHD Graphics on macOS Sierra and Later on Desktops [Clover/OpenCore]
So, the pink screen is on the built-in screen or the external DP/HDMI monitor?
pink screen is on built-in display (I dont know if the connector type is HDMI or LVDS), its an AIO (Dell Optiplex 7460), QE/CI is enabled. (I have not enabled Digital Audio as yet).
I have set Con-1 type as 00 08 00 00 but may be I need to change it to LVDS?
Check manual/spec sheet to get the connector info. You can also use Windows/Linux Live to determine the same.
Third-party parts info says LVDS
whereas Linux says HDMI (o means connection number/index ?)
(QE/CI enabled. But this is how it appears as pink)
IO Reg shows connector type set a HDMI 00 08 00 00 yet the display is pink
I'm using hackintool. Perhaps I am doing something wrong with connectors patching.
(config is attached, Clover based, I'm using these Device Properties from another user's config)
kindly respond please @EliteMacx86
Don't tag unnecessarily. You should wait for at least 24hrs before you bump. You already agreed to the rules when signing up!
This is a weird issue and have seen it on CML AIOs as well (Dell only) so far. You can try removing the connector type for all the connectors and check if that resolves the issue.
Reactions: Lenovo-M93Z-AIO
I'll follow the rules.
I removed the connector types for all, rebooted and the display turned off while OS was loading. It didn't solve. Could there be somthing wrong with BUS ID values/patching?
So, still pink screen then?
ramospa
