Need little help in error related to Lilu
Victus by HP Laptop 16-e0xxx
AMD Ryzen 5 5600H with Radeon Graphics
RX 5500M(got burned due to short-circuit so currenty not available(disabled))
I created EFI for my HP Victus Ryzen 5 5600h Radeon graphics to install macOS sequoia 15,,but for some reason it getting stuck in this kind of error (Lilu patcher : @ failed to solve)
I tried to update Lilu.kext but still it sticks at ((IOG flags 0x3 (0x51))
Any help is appreciated
  • EFI.zip
    EFI.zip
Why are you using ResetLogoStatus?
Why are you using FixupAppleEfiImages?
You should consider disabling IntelMKLFixup and also NootedRed
Why are you using CustomSMBIOSGuid?
Why are you using Custom UpdateSMBIOSMode?
Lastly, what's the DVMT pre-alloc memory size?
I have no idea about that , I used OP-core simplify to create EFI, I am sorry..😂,
Thank you so much you helped me even EFI is not asper guide,,Let me try to fix it
Sure, not an issue.
Sure, not an issue.
I removed NootedRed IntelMKLFixup from above EFI and added Whatevergreen.kext and I successfully installed macOS Sequoia but there is no graphics acceleration
Wallpaper is white and Graphics Display 7 MB issue
How to get Graphics acceleration any idea ?
You were not instructed to use WEG. WEG should NOT be used with NootedRed.
That's nice!
That's expected!
Reactions: AloneWarrior15
I tried above guide , since it is for macOS Sonoma NootedRed works with that , but I am on macOS Sequoia 15.3.1 latest version so ,currently NootedRed is not updated on 'chefkiss' or i am unable to find it online...
Which kext did you use and from where? Just pushed an update to the NootedRed. Try that and report if it works.
I forked it from chefkiss github 'Artifacts.zip(NootedRed.kext)' ,,,,, and then I tried updated NootedRed from our download section 'Artifcats.zip'(NootedRed.kext) ,,,,, I did Reset NVRAM and updating 'plist' everytime ,,,,, Both having same error as above image -> Above image link
There is a KP. Attach your EFI to check!
nhatly2015
