ThinkBook 14 g6 with ryzen 7 7730U
Could you please create the efi for me? I can't figure out what the error is.
Model: LENOVO THINKBOOK 14 G6 ABP
amd.
Processor: AMD RYZEN 7 7730U
ram.
RAM memory: 16GB DDR4
Disk
Storage: 512 GB SSD NVMe PCIe
screen.
Screen: 14" FHD WUXGA
integrated amd radeon graphics
No. That is your responsibility
We're here to help!
Why are you using EnableWriteUnprotector and RebuildAppleMemoryMap together? Use the latter one.
Disable UnblockFsConnect
Thanks for your help, I made the corrections and I'm still having problems.
Remove SSDT-CPUR and replace it with SSDT-PLUG-ALT.
Try with the following Quirks combination:
1. Combination First
RebuildAppleMemoryMap - Enabled
DevirtualiseMmio - Enabled
EnableWriteUnprotector - Disabled
2. Second Combination
RebuildAppleMemoryMap - Disabled
DevirtualiseMmio - Disabled
EnableWriteUnprotector - Enabled
3. Third Combination
Also, disable LapicKernelPanic. Its likely not required for your hardware!
The rest of the quirks will remain as it is.
Hello, the second combination was the solution. but the touchpad does not work and the language is in Russian
The trackpad will not work, until you patch it. Must be I2C.
Regarding the Russian Language, ensure that the language is set properly in the NVRAM. Look for the prev-lang:kbd value.
Hello, sorry for the inconvenience, when installing the installation it stops and the following screen appears, what could be happening?
What's the boot disk model?
WYLDE983
