 - Jan 1, 2020
 - Lenovo IdeaPad S540-15IWL GTX
 - Intel i7-8565U
 - Intel UHD 620/NVIDIA GEFORCE GTX 1650 Max-Q
 - 10.13.x
 - Clover (UEFI)
With this config (config_HD615_620_630_640_650.plist) i have Black screen after verboseThat's the wrong config.plist for your hardware. You must use "config_HD615_620_630_640_650.plist" . Note that the UHD 620 and UHD 630 are really different. UHD 630 is CFL and UHD 620 can be from KBL-R or WHL.
You can use the SSDT and just add the rename for the SSDT (if needed) in the original config.plist. Make sure you don't modify rest of the config.plist except enabling verbose.
I've done couple of WHL Laptops and never needed the RTC fix. I tested Mojave and Catalina.
Reply with new files.
