Black screen when booting into installer
Set the Picker Mode to Built-in and set Picket Attributes to 1.
Remove IntelMausiEthernet and replace it with IntelMausi
Disable AppleXcpmExtraMsrs
Looks good. Try to boot now and attach the boot video.
It takes a while to boot into recovery. What macOS version are you trying to boot? And what does the recovery media looks like?
i waited for about 2 minutes but it still stuck
im trying to boot into ventura
using the online method
That's weird. Post the picture of the content directories of the USB.
Looks good. What are the BIOS Settings and is your BIOS up to date? Try booting other installers such as Monterey or Big Sur and then check.
My bios is up-to-date
I checked my bios settings and it's set like dortania open core guide
I will try monterey and see
I tried with monterey but when I pick the dmg it restarts the pc
ilikeeatingpeeandpoo
