Black screen when booting into installer
I tried with the release version but still black screen also what is the pr files ?
Hardware Information:
Dell precision t3600
CPU:Intel xeon e5 1620
GPU:Nvidia gtx 960
Ram:16gb
BIOS SETTINGS
Vt for io:disabled
Disk are set to achi
There is no secure boot option
Tpm: disabled
The same thing just happend and I provided a video above
Also there's no verbose
4- the efi is attached above also there's a log file but it's empty
GPU:Nvidia gtx 960
Ram:16gb
BIOS SETTINGS
Vt for io:disabled
Tpm: disabled
GTX 960 isn't supported natively. What macOS version are you trying to install?
Every time you make any changes to the EFI (this time, you had to switch to the RELEASE version), you'll need to provide the EFI to validate the changes.
trying to install ventura
Here are a few issues. Make the following changes to your config.plist:
Remove SSDT-EC, SSDT-SBUS, SSDT-USBX and replace it with SSDT-EC-USB-DESKTOP and SSDT-UNC
Remove ResetLogoStatus
Remove FixupAppleEfiImages
Remove Device Properties
Remove all the kexts except for Lilu, VSMC, WEG, Ethernet, CpuTscSync, CryptexFixup, RestrictEvents.
Remove CustomSMBIOSGuid if the machine is not Dell/SONY.
Enable XhciPortLimit
Enable SIP and remove all the boot flags related to NVIDIA patching and add nv_disable=1
Set UpdateSMBIOSMode to Create if the machine is not Dell/SONY.
Reactions: MistaWhite
i did the changes, reset the nvram twice tried to boot but still stuck at black screen
WEG is missing.
Is the machine a Dell computer?
Add the kext and provide a video showing booting the installer
Added WEG
Yes the machine is dell
still black screen
Set the Picker Mode to Built-in and set Picket Attributes to 1.
Remove IntelMausiEthernet and replace it with IntelMausi
Disable AppleXcpmExtraMsrs
gopon_user
