Black screen when booting into installer
MistaWhite
Intel Xeon E5-1620 @ 3.60GHz
NVIDIA GeForce GTX 960
Black screen When i try to boot into mac os installer
i tried every mac os installer from high serria to ventura but not working
i tried also prebuilt efis but also no luck
Here is my efi and log file
Do you see the OC picker?
Yes ,then it shows 3 entries one usb , usb (dmg) , nvram reset
When I pick the usb (dmg) it gives me black screen then reboot
When I choose usb only it shows some code and it ends with halting critical error
Okay. Can you provide a video?
Okay. Switch to the RELEASE version and then provide the PR files.
I tried with the release version but still black screen also what is the pr files ?
kocsik
