SOLVED UHD Graphics 620 in Whiskey Lake HP laptop not working
JoseDanyR
HP ProBook 440 G6
Intel Core i5-8265U
Intel UHD Graphics 620
Hi! My laptop is a HP ZBook 14u G6, i7-85658U, UHD 620 and a 4K display. I've tried following every single guide and instructions in Dortania, Reddit, Discord and many other, but no progress
If I set AAPL,ig-platform-id only, it will boot without graphics acceleration, if I try "device-id" or any framebuffer memory patch it won't boot or just simply restart. I've tried multiple SMBIOS and device-id's.
Can any one help me, please? Thanks in advance!
EDIT: I managed to get the iGPU working.
Visit https://github.com/JoseDanyR/HP_ZBook_14u_G6_Hackintosh_WhiskeyLake for EFI folder and DeviceProperties patches
Attach your EFI to check!
Of course! here it is
(Page won't let me upload zip)
Why are you using SSDT-GPU-SPOOF?
The reason why it restarts is because there is a KP. This is because the framebuffer is not patched correctly.
xmax114
