VoodooHDA doesn't work on macOS Sequoia on Ivy Bridge
muhammadbahaa2001
Toshiba
Intel Core i3-3120M
Intel HD Graphics 4000
15.x
Audio not working in macOS Sequoia even with VoodooHDA kext latest version, which is 3.0.2, even when I installed it to /Library/Extensions with disabled SIP.
I made sure that VoodooHDA is removed from EFI.
What should I do more?
What's the Audio Codec?
ALC269
I remember somehow it was working on Sonoma and lower, but after clean install of macOS Sequoia, it no longer working
I guess it relates to csr-active-config although I tried many of values.
Go to system pref>security and press ALLOW if exist
I did that
But at I discovered that my SIP status is custom/unknown although I have disabled it
I tried many csr-active-config values with NVRAM reset but still can't completly disable SIP.
alvarg82
