Intel UHD 620 HDMI output is not working
pawan2joy
Thinkpad X390
i7 10510 1.8Ghz
Intel UHD 620
15.x
HI, I have tried many options but my HDMI output on Intel UHD 620 is not working.
My specs:
Lenovo Thinkpad x390
CPU: Intel i7 10th gen 1.8 Ghz
GPU: Intel UHD 620 Graphics
have attached PR files for you to dig inside please.
My specs:
Your EFI is not as per the guide. Why are you injecting double SSDT-PLUG?
Beside the internal display and HDMI port, are there any other ports for display on this Laptop?
Dont know why its double someone else helped me to make it work, apart from HDMI i have Display port.
Can you please help me here
Provide the pictures of the ports.
here are the images.. One side it has Type C charging, 2 type C, USB, HDMi and Mic jack.. other side fan output and USB
But you mentioned you have DP as well ;(
Attach the EFI and a copy of IOReg to check further!
IOREG file and EFI (removed resources and itlwm to save space)
Hi, can you please help me with this
The files are corrupt. Re-upload correctly to check.
see if these are ok
ryusuke17
