Asus Vivobook X512DA
same problem i have KP i need to put voodooELAN.kext? or just voodooi2c.kext and voodoo2CHID.kext
attach config.plist latest (after adding voodooSMBUS.kext)
here the config.plist
Remove VoodooSMBus.kext and enable the following:
VoodooI2C.kext and VoodooI2CHID
In plugins for VoodooI2C.kext, disable VoodooInput.kext
If still it doesnt work, try disabling VoodooPS2Trackpad.kext as well.
If it still doesn't work, EliteMacX86 will probably find you a guide where u can make it work (probably).
PR files? what is PR files?
after remove VoodooSMBus.kext get KP
after disable VoodooInput.kext and VoodooPS2Trackpad.kext boot a few seconds then reboot
  • Sad
Reactions: ready2000
sorry here the files: https://www.mediafire.com/file/yr1fn8953m75hlu/Archive.zip/file
for
  • TRIM
    • log show --last boot | grep "trims took"
  • Kextcache
    • For OS X 10.10 and prior
      • sudo touch /System/Library/Extensions && sudo kextcache -u /
    • For OS X 10.11 and newer
      • sudo kextcache -i /.
i don't have any log
for system log I have sometimes crash because of nootedred kext
i have random freeze and reboot (I know because of nootred kext)
touchpad does not work
At this time I only want touchpad to get working
Use the latest kext and increase the VRAM.
Have you attached the Hackintool and IOReg?
yes like you said I have attached all PR files
ok how to increase VRAM? (there is no option inside bios)
ANARKRUTOI
