Asus Vivobook X512DA
after successully installed Sequoia and made test adding kexts with nootred no KP but when i update the kexts for touchpad i have this KP:
ok i will remove theses kexts you said thank you
you said "The thing is that, before installing macOS, you need very limited kexts, just so that it can install. All accessories can be installed later."
with the efi from github i install sucessfully ventura without delete any kexts....
Using someone's else EFI is NOT recommended and it doesn't matter whether it works or not.
after remove voodoo kexts for touchpad Sequoia boot sucessfully
What' working now:
Audio with https://chefkissinc.github.io/newsroom/applealc-sequoia/
Fn keys
Wifi with Heliport and itlwm.kext
BT seems to work scan devices but when connected disconnect immediatly
don't work:
touchpad
Sd car reader (Realtekcardreader.kext and RealtekcardreaderFriend.kext) does not seem to detect
Need help to get working the touchpad
For Trackpad, determine whether its on the PS/2 or I2C bus. Then, install appropriate kexts. Some I2C trackpads may require ACPI patching as well
the trackpad is an ELAN 1200, I don't know how to patch ACPI... and know I don't know why the notebook always freeze because of nootred kext
Sounds like an I2C bus. Provide the PR files to confirm.
can someone explain why when i want to change my avatar on my profile on sequoia or another system option the notebook always freeze and reboot or freeze and i need to force shutdown???? i can apply amdfriend to resolve this issue?
mulineee21
