 - Oct 15, 2024
 - Asus Vivobook X512DA
 - Ryzen 5 3500U
 - Vega 8 graphics
Using someone's else EFI is NOT recommended and it doesn't matter whether it works or not.ok i will remove theses kexts you said thank you
you said "The thing is that, before installing macOS, you need very limited kexts, just so that it can install. All accessories can be installed later."
with the efi from github i install sucessfully ventura without delete any kexts....
For Trackpad, determine whether its on the PS/2 or I2C bus. Then, install appropriate kexts. Some I2C trackpads may require ACPI patching as wellafter remove voodoo kexts for touchpad Sequoia boot sucessfully
What' working now:
Audio with https://chefkissinc.github.io/newsroom/applealc-sequoia/
Fn keys
Wifi with Heliport and itlwm.kext
BT seems to work scan devices but when connected disconnect immediatly
don't work:
touchpad
Sd car reader (Realtekcardreader.kext and RealtekcardreaderFriend.kext) does not seem to detect
Need help to get working the touchpad
VoodooSMBusthe trackpad is an ELAN 1200, I don't know how to patch ACPI... and know I don't know why the notebook always freeze because of nootred kext
Sounds like an I2C bus. Provide the PR files to confirm.the trackpad is an ELAN 1200, I don't know how to patch ACPI... and know I don't know why the notebook always freeze because of nootred kext
PR files? what is PR files?Sounds like an I2C bus. Provide the PR files to confirm.
same problem i have KP i need to put voodooELAN.kext? or just voodooi2c.kext and voodoo2CHID.kextVoodooSMBus
Try this kext.
