Sequoia installer stuck on Apple Logo with progress bar, please help / Ryzen 5 5600x / Radeon RX 570 OC
elii_wnl
Asrock B450 Steel Legend
AMD Ryzen 5 5600x 6 Cores
AMD Radeon RX 570 8GT OC
So I've made an EFI for my for my specific configurations and I have been able to boot into recovery and install Sonoma, Ventura, and previous versions of macOS using my efi but whenever i try to freshly install or upgrade to Sequoia, it always gets stuck at the apple logo with the progress bar at the bottom that will not move. I've upgraded to OpenCore bootloader 1.0.1, upgraded lilu, vsmc, and whatevergreen kexts, and installed the latest patches for AMD Hackintosh and still I'm running into the same issue. I've included my efi below so maybe someone with more experience can take a look at it and help me identify where i went wrong. Thanks for your time <3
Set ResizeappleGpuBars to -1 in the config.plist and also ensure that Resizable BAR is disabled from BIOS.
Also, have you updated the Kernel Patches for Sequoia? If not, that's the issue.
Hi! So I had already installed the latest kernel patches & I just tried setting ResizeappleGpuBars to -1 and disabled it from my bios and still no luck. I added -v to the boot arg to try and get some insight but still not sure what could be causing the issue. I've included my updated EFI and a photo of the panic down below :)
Remove the following kexts:
The issue is you're using iMacPro1,1 in the USBMap kext whereas, the config.plist has MacPro7,1. Changing the SMBIOS to iMacPro1,1 will let you boot.
Still, the config.plist is dirty and not as per the guide.
chirag11122
