This patch is only for Skylake. You're having a Kaby lake system. So the patch doesn't applies to your Laptop.
Is there a patch for kaby Lake then ?
Any issues with the extracted files?
It created a dumplog and the refs.txt file is present but it didn't disassemble it.
using "iasl -da -dl DSDT.aml SSDT*.aml" instead of 'iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml" , i get one error. Screenshot 2019-12-12 at 11.25.08.png
using "iasl -da -dl DSDT.aml SSDT*.aml" instead of 'iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml" , i get one error.View attachment 1969
What's the issue when using the refs.txt? Any errors with the disassembly?
it did the disassembly process but didn't create the dsl files
i used---> iasl -da -dl DSDT.aml SSDT*.aml <---- as iasl -da -dl -fe refs.txt DSDT.aml SSDT*.aml shows some output in terminal but provides no disassembled files
Can you provide a video explaining it?
And provide your fresh ACPI files. Make sure it's the latest, extracted fresh.
Reactions: Chucksmmadu
here's the video. I couldn't upload directly, so i compressed it.
oleksii
