Good day elitemacx86, here's my pr file :)
I also attached a log file for my acpi files disassembly process using the "iasl -da -dl DSDT.aml SSDT*.aml" to extract :( (maybe it might help).
Why you didn't used the refs.txt file?
But using "iasl -dl DSDT.aml SSDT*.aml" to extract, i get this instead.. I'm now confussed... I don't even know if my battery patch is to be blamed o_O:( What bugs me most is that it carries over this weird behaviour to windows 10 and my battery has never charged up to 100% for over three days now even if i leave it plugged for over 8 hours 😰😰
I mentioned about the issues. And it will only charge if no OS is loaded. Means in a shut down mode. To charge, do the steps below.
Shut down your Laptop
Plug your AC Adapter and it will start to charge.
I tried that but unfortunately, it made no difference :(
I made a mistake omitting that 😞... i will re-extract and re-patch my files again using the refs.txt.. From what you've seen so far, i think its safe to say that my files need the -da for extraction right?
Yes, you must use the command i mentioned in the guide. The extraction must be done using refs.txt.
Reactions: Chucksmmadu
I will do that and upload files after that
kod_mic
