Hi, I have Catalina on my laptop as shown in my profile.
I disassembled origin with no error.
Open dsdt with MaciASL and just press complie btn to see are there any errors and there was 3. I attached photo of them. How can I fix them ?
5863, 6126, syntax error, unexpected PARSEOP_ZERO
5908, 6126, syntax error, unexpected PARSEOP_ZERO
10320, 6126, syntax error, unexpected PARSEOP_NAME, expecting $end and premature End-Of-File
  • biglibigli.zip
    biglibigli.zip
Ok thanks for this! I've applied it... I think my dsdt patches are now complete... But my battery capacity is still wrong... Sometimes, it sayd plugged in not charging same behavior in windows 10 as well. Does it mean i need a battery replacement? 🤔
Apply "[syn] Fix PARSEOP_ZERO Error (aggresive) patch from the error. It should be error free.
This is a common issue with many HP Laptops. Especially the Pavilion series. If it's same in Windows 10, two reasons.
1. The battery replacement is needed.
2. Battery still has capacity and power but the mosfet which handles the battery charging, is defective.
Reactions: Chucksmmadu
thanks, All errors gone by deleting zeros causing error. :)
I used these patches on DSDT :
audio Layout ID 3
Rename GFX0 to IGPU
Fix _WAK Arg0 v2
Fix Mutex with non-zero SyncLevel
HPET Fix
IRQ Fix
OS Check Fix
RTC Fix
SMBUS Fix
Haswell LPC
6-series USB
7-series/8-series USB
and not used these :
-----Rename B0D3 to HDAU
-----Fix PNOT/PPNT (use only if you're dropping CPU related SSDTs)
-----Add IMEI (do not use if your DSDT or SSDTs already have IMEI/HECI/MEI device)
result :
Audio worked. (y)
Wireless AC Atheros ATH9565 NOT work (how can I be sure this is my exact wifi model ?)
touchpad NOT work. (must be I2C again not sure)
Battery icon showed but always 0% and when I unplug adapter says no battery connect adapter
How can I fix these ? :unsure:
I didn't patch any SSDTs because there is many and I don't know which one should I open and patch !!!
  • biglibigli.zip
    biglibigli.zip
Perfect!
Haswell LPC
6-series USB
These are not intended for your Laptop. Looks like you forgot to read the notes.
Your WiFi is Qualcomm Atheros QCA9377 as per the Device ID which is incompatible. Replace with a compatible one
You need to patch DSDT for it. Read here:
Did you applied the battery patch?
Patching SSDTs is a full configuration which i recommend. You need to follow the guide.
Haswell LPC
6-series USB
my mistake ,should I undo these ? also don't know how !
Documentation
I will do it
yes I did. I also had ACPIBatteryManager.kext in clover kext
does it have a full guide thread ? can you mention it ?
Notes were there. Probably, you didn't read or didn't understood.
Which battery patch you applied?
Yes, of course. Read here:
Scroll down to SSDT patch.
Reactions: biglibigli
Good day elitemacx86, here's my pr file :)
I also attached a log file for my acpi files disassembly process using the "iasl -da -dl DSDT.aml SSDT*.aml" to extract :( (maybe it might help).
But using "iasl -dl DSDT.aml SSDT*.aml" to extract, i get this instead.. I'm now confussed... I don't even know if my battery patch is to be blamed o_O:( What bugs me most is that it carries over this weird behaviour to windows 10 and my battery has never charged up to 100% for over three days now even if i leave it plugged for over 8 hours 😰😰
nicolacibin08
