Intel Gigabyte Z490 Vision D
It wont work even after taking one of them out, could it be an OS version issue?
Where do I get those PR files from?
Hey here are the files you asked for. I did add a couple of things to try and fix TB issues but no such luck.
Was that the files you asked me for?
The TB implementation looks fine. What's the problem? What TB device are you using to test the hotPlug function?
dodikhokh
