About memory errors
nitsuki
DELL inspiron 5435
Ryzen 5 7530u
AMD Radeon proseccer
Before starting the installer,
"** In Memory Panic Stackshot Succeeded ** Bytes Traced 7213 (Uncompressed 25552) **" is displayed and it gets stuck.
The composition is
DELL laptop inspiron 5435
CPU:Ryzen5 7530u
dGPU: None
iGPU: Radeon APU
Memory: 16GB
I will post the EFI
The composition is
CPU:Ryzen5 7530u
dGPU: None
iGPU: Radeon APU
Memory: 16GB
I will post the EFI
The boot arg is npci=0x200. You have a typo.
In addition, enable DevirtualiseMmio and then check
got it !
I will try.
sorry. I tried that but it didn't lead to any improvement. When I created the EFI, I didn't know the layout-id and entered a random number, but does that have anything to do with it?
or is it because some items were not found in the UEFI settings and were skipped?
In any case, I don't know. Could you please tell me?
No, it does not matter as the problem is coming from somewhere else.
Try the attached SSDT. Remove CPUR.aml.
添付の SSDT を試してください。CPUR.aml を削除してください。
EFIを変更しましたが、動作は変わりませんでした。現在のEFIを添付します。
Sorry !
I changed the EFI, but the behavior didn't change. I have attached the latest EFI.
Can you provide the CPU model from BIOS?
AMD Ryzen 5 7530U With Radeon Graphics
2000MHz
CPU ID: A50F0
fierofree
