And there is the new efi revised
Enable DevirtualiseMmio and EnableWriteUnprotector+SyncRuntimePermissions Quirk and then check.
It's finally ok! I managed to boot now, but now I only have 7MB of video memory and not 16MB
That's nice. Seems like you forgot to enable those quirks. They were already mentioned.
Now, its time to remove -igfxvesa boot arg and patch the framebuffer.
Can you give me the framebuffer patch ?
I have test with device-id: 923E0000
And doesnt work
And doesnt work
I read and i try, but doesn't work. Also 7mb..
I tried with the framebuffer patch and without the framebuffer patch and same problem.
I am connected via HDMI and my DVMT is set to 64mb
Attach a copy of IOReg with the above EFI.
Here it's my IOReg. It's the good file ? Or Information ?
Rajala1404
