Hello !
Successfully managed to get a GTX 1080 Ti working under Ventura 13.6.8 using OCLP 1.5.0 for a friend. I didn't use the boot-args amfi_get_out_of_my_way but I used AMFIpass.kext (1.4.0) instead ! Worked totally fine. After patching, I was stuck on a blackscreen... But it was related to the HDMI output being used !!! So I changed the output to DVI (because my friend didn't have Display-Port cable at home). Thank you !
That's nice!
Reactions: Mazarinpolis
My friend told me that he can't open FL Studio on his Ryzentosh. Can it be OCLP / Nvidia patching related ?
No, its not. Its due to the CPU which require a patchset. Similar to Adobe and other Apps on Ryzen. When opening the FL Studio, it crashes right?
When he wants to launch it, nothing happened... He's on Ventura 13.6.8. Here he's config : Ryzen 5 3600, Asus TUF B450-Plus Gaming II (last BIOS) and the GTX 1080 Ti.
Use the above linked guide to patch the MKL Libraries.
HI
WHAT SHOULD I INSTALL MAC OS VERSION IN MY LAPTOP ZBOOK G6
CORE I7 9850H
16G RAM
QUADRO T1000 4G
HI
CORE I7 9850H
16G RAM
QUADRO T1000 4G
Firstly, you should check whether the IGPU is factory disabled or not.
can the first page's screenshot be updated to use 2.1.2? it don't show the web drivers force checkmark, thx
Thanks for pointing out. Will be done soon :)
xxxxxxxxxx
