AppleALC not giving any Audio Ports in macOS Sequoia.
@Sayor0603 Its just one week after release. Still in beta, so by the final release, there should be improvement for sure. Try to spoof the Device-ID and then check if it works.
Reactions: Sayor0603
use Gfxutil tool and find HDEF
It gave this.
tahsinfaiyazsayor@Tahsins-iMac ~ % /Users/tahsinfaiyazsayor/Downloads/gfxutil-1.84b-RELEASE/gfxutil -f HDEF
0a:00.6 1022:15e3 /PCI0@0/GP17@8,1/HDEF@0,6 = PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x6)
where is the device id in it?
Oh Opencore Boot Chime is working. I can hear the boot-chime sound.
It gave this.
1022:15e3 is the VEN and DEVID
In macOS Sonoma, appleALC worked. But when I upgraded to Sequoia, AppleALC no longer works.. this is my config. Ignore the NootedRed..
Motherboard: Gigabyte X570S Aorus Pro AX (rev 1.1)
Audio: Realtek 1220-VB
Did you find the solution for audio?
My audio was working perfectly in Sonoma, but as soon as I updated my Mac to MacOS 15 then the audio stopped playing
Yeah same
Reactions: Aniket022
Yeah same
Brother, the kext has just been updated on the Opencore website, use the new AppleALC kext, and also update the LILU and RestrictEvents kext. The sound problem will be fixed
fierofree
