AppleALC not giving any Audio Ports in macOS Sequoia.
Sayor0603
Gigabyte X570S Aorus Pro AX (rev 1.1)
AMD Ryzen 5 5600G
NA (Integreted Vega 7)
15.x
In macOS Sonoma, appleALC worked. But when I upgraded to Sequoia, AppleALC no longer works.. this is my config. Ignore the NootedRed..
Motherboard: Gigabyte X570S Aorus Pro AX (rev 1.1)
Audio: Realtek 1220-VB
In macOS Sonoma, appleALC worked. But when I upgraded to Sequoia, AppleALC no longer works.. this is my config. Ignore the NootedRed.. Motherboard: Gigabyte X570S Aorus Pro AX (rev 1.1) Audio: Realtek 1220-VB
Attach Hackintool, System Report and copy of IOReg.
Reactions: brandal
Hackintool:
Note: I gave Hackintool PCI Devices in the pcidevices.txt
System Settings:
System Information:
IOreg:
Attach a copy of IOReg. Not the screenshots. Also, what's the audio codec?
My audio Codec is Realtek 1220-VB
HEre is the copy of ioreg:
Remove Device Properties for Audio and try to inject Layout ID = 11
Yeah was completely fine. even HDMI audio, mic and all the ports
Try injecting different layout IDs. If that does not work, will have to wait for an update from acidanthera.
Reactions: DAEMONS
fierofree
