Need help, stuck at "start::512:successfully initialized ahci controller"
stattrack
Gigabyte B550 X Gaming V2 1.4
Ryzen 5 3600
RX 6600
When I try booting into my mac os sonoma installer, I get this error every single time.
I think I have done everything correctly (I have followed a ryzentosh guide aswell) and I don't know whats causing this error.
enabling "Resizable Bar" in bios makes me end up with a different error.
Can anyone help? I've attached my EFI folder below.
  • EFI.zip
    EFI.zip
Enable SetupVirtualMap and DevirtualiseMmio.
Also, your EFI shows that your ports are mapped. Did you actually do it? If not, remove it and just enable XhciPortLimit for the meantime.
I have used a tool called USBToolbox, i just followed the instructions in a video and I guess it worked? My friend says that's what he did and its fine.
I've tried with those two settings off and im still encountering the same issue
Is your BIOS updated? What BIOS settings have you done? Ensure that Resize BAR is disabled in BIOS.
xmax114
