Struggling with Dell XPS 9300
EFI looks good now. Remove force online entry and check if your display works normally. force online breaks certain functions when the laptop enters sleep mode.
I noticed a bit of artifacts on screen when changed from verbose to UI but it's not a big problem. May i need a proper installation to confirm. I'll report back later after finishing.
Well, that's good. Where's the treat then? 😛
Haha, of course.
Would need a video to see the issue.
I'll send it here when possible, now its time for me to get to work. Have a good day my friend!
Anyway, what do you mean by "the treat"? Sorry, English is not my native language, i can only understand basic english xD.
Sounds good!
You too!
Treat is like a special and enjoyable occasion or experience, often a reward or celebration for success/achievement.
A way to celebrate ;)
  • Love
Reactions: CaHoiHop
Got it!
Unfortunately, the seller sent me an BC501 SK Hynix instead of an WD SN750. I'm eligible for a refund in 30 days term, so i took a try. I also saw some success installations with exact same SSD as mine so i'm very confident.
But sadly, i still got the same "macOS Installer" boot loop as the intel ssd before. Now i trying to update a firmware for this ssd and give it a try!
Well, why did you not buy WD SN750 in the first place?
BC501/PC711/BC711 are incompatible with macOS. xD
Yes i did, but it's out of stock. But instead of informing me, the seller send me a BC501 instead, that's normal in my country haha. Now i had return it to the seller and buy an WD M2.
Why i still see some success install with it? Exactly same model with mine
Umm, go for WD SN850/850X then. It should be available. BC501 is an OEM model, not retail.
Could be a different firmware. xD
I tried some different firmwares but no luck.
It won't. Those are completely unsupported NVMe. Also, how did you flash different firmware for OEM drives such as SK Hynix?
Write your reply...
ambruhidot
