MacOs going in bootloop after installing macos sequoia beta
Youseffo13
Lenovo-Ideapad-3-15IML05
i3 10110U Comet lake U/Y
intel uhd630
15.x
Today i tried to update my mac to mac os sequoia. After the update was installed i tried to run mac os but it will going only on bootloop.
EFI Folder
Reactions: MvTech
EFI Folder
See here:
The problem Is that i even can't access to the system
You can make changes to the EFI on any other system using Windows or Mac and then boot externally to complete the installation phase.
The problem Is that i can't even access the system
Ok but what modify should i do?
I tried but not working
kod_mic
