Kernelmanagerd is not active error after installing macOS Sequoia
tropii
Dell Inspiron 3650 Motherboard
Intel Core i5 7400
GTX 1050
After installing macOS Sequoia, I would run into an issue where it says kernelmanagerd is not active. I would get another error where hardware acceleration was not able to be enabled. This system runs macOS Sonoma just fine and has 0 issues even though its a low-end machine.
-- System Specs --
CPU: Intel Core i5 7400
RAM: 32 GB
GPU: NVIDIA GTX 1050
Storage: 128 GB SSD & 1TB HDD
OCLP Version: 1.0.0
Kexts are up to date
Is there any way to fix this issue?
-- System Specs --
RAM: 32 GB
OCLP Version: 1.0.0
OCLP isn't ready yet. You should be able to use HD630.
mulineee21
