13700KF + RX 6950 XT Problem
RayZee888
Gigabyte B85M-D3H
4590s
RX 580
Hello,
Since yesterday I have been struggling with the Sonoma installation on 13700kf, RX 6950 XT. I tried creating my own EFI folder, but things kept failing, so I downloaded the one ready to install on a 12/13 generation Intel. The installation has started, the system is installed. Of course, now there is a problem with graphics. I knew I'd have to pretend it was an RX 6900 XT, but I didn't know it would have so many problems. There is no way I can get it to work properly. I am attaching the content of the SSDT-GPU-SPOOF.aml file and a screenshot from the Windows device manager:
* Intel ACPI Component Architecture
* AML/ASL+ Disassembler version 20200925 (64-bit version)
* Copyright (c) 2000 - 2020 Intel Corporation
* Disassembling to symbolic ASL+ operators
* Disassembly of iASL30ctHP.aml, Sun May 19 19:37:51 2024
* Original Table Header:
* Signature "SSDT"
* Length 0x000000FC (252)
* Revision 0x02
* Checksum 0x9F
* OEM ID "EMX86"
* OEM Table ID "GPUSPOOF"
* OEM Revision 0x00001000 (4096)
* Compiler ID "INTL"
* Compiler Version 0x20200925 (538970405)
DefinitionBlock ("", "SSDT", 2, "EMX86", "GPUSPOOF", 0x00001000)
External (_SB_.PCI0, DeviceObj)
External (_SB_.PCI0.PEG0, DeviceObj)
External (DTGP, MethodObj) // 5 Arguments
Scope (\_SB.PCI0.PEG0)
If (_OSI ("Darwin"))
Device (GFX0)
Name (_ADR, Zero) // _ADR: Address
Method (_DSM, 4, NotSerialized) // _DSM: Device-Specific Method
Local0 = Package (0x08)
"AAPL,slot-name",
Buffer (0x07)
"Slot-1"
"device-id",
Buffer (0x04)
0xBF, 0x73, 0x00, 0x00 // .s..
"no-gfx-spoof",
Buffer (0x04)
0x01, 0x00, 0x00, 0x00 // ....
"model",
Buffer (0x17)
"AMD Radeon RX 6900 XT"
DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0))
Return (Local0)
Any help?
  • EFI.zip
    EFI.zip
Hello,
* Signature "SSDT"
* Revision 0x02
* Checksum 0x9F
* OEM ID "EMX86"
Device (GFX0)
"AAPL,slot-name",
Buffer (0x07)
"Slot-1"
"device-id",
Buffer (0x04)
"no-gfx-spoof",
Buffer (0x04)
"model",
Buffer (0x17)
Return (Local0)
Any help?
Your GPU path must match the SSDT. Otherwise, the spoofing will not work.
The graphics card works, but it doesn't support h264/hevc. DRM content playback also doesn't work.. The ID is shown as 6950xt.
  • ssdt.zip
    ssdt.zip
  • config.plist.zip
    config.plist.zip
IOReg is missing.
raymondleung416
